has any 1 used this stuff before ?
Old Nov 29, 2011 | 05:51 PM
  #31
xgiovannix12's Avatar
yes i found the symbol for the resistance on the manual and its 67
Old Nov 29, 2011 | 05:58 PM
  #32
Too much, should be less than 5 ohms, that's why it's hot. Follow it back until you find the poor connection, or run a new wire, using 10 gauge wire.
Old Nov 29, 2011 | 06:03 PM
  #33
I followed it all the way to the driver side where the wire comes out of the body
i got lower once i got to the wire on the driver side by the body 65 resistance
Old Nov 29, 2011 | 06:04 PM
  #34
burning_soul07's Avatar
burning_soul07 is on a distinguished road
I had this same problem. Had to make a new connection to the window at the passenger side. Then had to track down where I had a bad connection. My bad connection was where the wire screwed into the arm, it was dirty and didnt get a good connection. After I cleaned both sides out the rear window defogger worked great again.
Old Nov 29, 2011 | 06:06 PM
  #35
can it be i have a problem in the harness ?
or the plugs that go on the struts have to be replaced
Old Nov 29, 2011 | 06:10 PM
  #36
Check resistance between the terminals on the strut, that should also be less than 5 ohms. Yes the problem could be in the harness, but most likely where it attaches to ground after it comes out of the harness.
Old Nov 29, 2011 | 06:17 PM
  #37
Ok i did this from the passenger side the wire from the body had 5 ohms so i connected it to the strut I tested at the other tip of the strut and i had 5 ohms now i connected the window wire and tested the grid and i had 5 ohms
I tryed the wire on the other side of the glass and i had 5 ohms I connected the wire to the other strut and had 5 ohms on the other end of the strut
When i test the wire coming out from the body on the drivers side it reaches 65 ohms
I guess i need to pull the rear panels off tomorrow
Old Nov 29, 2011 | 06:21 PM
  #38
Driver side will show volts, not ohms. All you need on the driver side is for it to show battery voltage when the defroster is turned on.
Old Nov 29, 2011 | 06:36 PM
  #39
so that means every things ok then right ? if i test the body wire from the driver side i get 13 volts
if i connect the wires all together the passenger sides ohms would be 67
Edit: I connected every thing again I tested every thing all the 3 plugs have 5 ohms and the driver side body wire has 13 volts
so i guess every things ok
edit2: I tryed it again and the wire hot real hot again sigh i give up for tonight
Old Nov 29, 2011 | 06:51 PM
  #40
You must check resistance at the wire connector on the passenger side, (ground) with the connector unplugged from the grid. Gotta be 5 ohms or less.
