Heater blower motor
Old Nov 16, 2008 | 10:25 PM
Whutdidyousay's Avatar
Whutdidyousay is an unknown quantity at this point
Default Heater blower motor
My heater blower motor quit working tonight. I immmidiately came home and checked this forum and looked over a few ideas. after checking the fuse and connections behind the switch I tapped on the motor and it immidiately started working.
My question is... after reading that it's most likely just a loose connection inside the blower..... can I disassemble the motor and solder the connections? my luck will say no, but I'd be a fool not to ask. I'm ready to pay the $24 to get a new one, but would rather not.
Thanks guys, you've already helped me save over $3000 in labor on this truck!
Old Nov 16, 2008 | 10:29 PM
Default RE: Heater blower motor
It is worth a try I suppose. More than likely though, it is not a loose connection, but a bad bearing that is causing the rotor to hang up. The motor does not have a lot of starting torque.
Old Nov 17, 2008 | 06:29 AM
mr.vls's Avatar
Before you go any further check the ground wire at the blower motor. There is a single wire that grounds the blower motor through one of the mounting bolts. The motor will not run or run intermittently if the ground wire is not tight.
maxvamp
Oct 31, 2020 08:19 AM
Turbo133
Jan 22, 2013 07:51 PM
DaveRush
Oct 12, 2011 11:10 PM
Riktar
Dec 21, 2010 11:20 AM
73Blazer
Nov 21, 2010 09:07 AM
