Locked my keys in 93 s10 blazer!! help please!
I just wanted to come back and say that I did eventually get it, I just cut a piece of 2X4 into a triangle shape like a door stop and then straightened out a clothes hanger. It took me about 5 mins.
If you have an electric opening rear window these are the easiest things to get into. Get another vehicle and ground that battery to the frame with a jumper cable. Now get under the back of the truck and you'll see a little rubber tube/hose that runs up into the tailgate. Pull it back and the wire you see is the window release wire. Strip a small cut in the insulation. Take the POS jumper from the other vehicle and just touch the bare spot and the window will pop open. Had to do this on more that one occasion with mine and some buddies' Blazers. You don't have to reinsulate the wire since it's inside the hose unless you want to. Hate to say it but these are the easiest vehicles to get into there are. Done the wedge thing and although it works you might bend one of the rods.
roaddog14
May 8, 2011 08:11 AM
Survivor
Sep 10, 2009 06:07 PM
Lilcheef
19
Jan 3, 2007 01:36 PM
