Passenger Side Window
Old Mar 22, 2010 | 09:55 PM
roae22's Avatar
roae22 is on a distinguished road
Default Passenger Side Window
Ok so i bought this cherry 88 s10 blazer.. but the passenger window was all the way down and would not budge.. right now i have the window detached from the arm and zip tied up.. any suggestions on what to check next? tried using the switch on both sides nothing happens and no noises..and the arm is stuck all the way down against the bottom of the door
Old Mar 22, 2010 | 09:57 PM
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
while pushing the switch, check and see if you're getting power to the window motor, try it both ways.
use a test light or a volt meter
Old Mar 22, 2010 | 11:35 PM
ohsofly's Avatar
Grab two wires long enough to go to your batter and connect them, then try hooking the wires to the motor. I think there will be 3 connections - ground, power up, and power down... If it dont move when you feed it known power, the motor is hooped.
upmaine
Jul 9, 2012 12:31 PM
408blazer
Jun 9, 2012 11:04 PM
burt
Sep 2, 2008 02:15 PM
bowanna03
Jan 8, 2007 11:23 AM
hillbillyinOhio
Jul 12, 2006 04:18 AM
