replacement knuckles exist on a 4wd?
Old Oct 3, 2018 | 03:20 PM
kallen90's Avatar
kallen90 is on a distinguished road
Default replacement knuckles exist on a 4wd?
I need a new one for the front left. I can't find any replacement knuckles for a 94 4wd s10 blazer. I can find 2wd all day long. Any help?
Old Oct 3, 2018 | 08:51 PM
Why does it have to be "new"?
Check and local salvage yards for a used one?
The knuckle itself isn't something that typically goes bad, breaks, or bends, unless the vehicle is in some sort of accident or just out right abused... Ball joints, tie rod ends, and wheel bearings however, that's a whole separate story
Old Oct 4, 2018 | 11:35 AM
kallen90's Avatar
When I broke the torque on the break caliber bolt it brought the threads on the hole with it. Its a smooth hole, almost....
the brake caliber bolt would grab the threads without the spacer, once I put the spacer on, it wouldn't grab the threads and I wasn't able to get the top caliber bolt to stay.
I ground the spacer for the by about 1mm and it fits great now. I thought I was going to have to replace the knuckle since I couldn't get the bolt to grab. It isn't the best fix, but it works, I'd much rather have a properly threaded hole than a half assed one.
Old Oct 4, 2018 | 12:36 PM
If I understand you correctly, your fix does not sound very solid. As for used, instead of pulling the part yourself, I bet you could get a wrecking yard to pull one for you and even ship it. These parts do not go bad.If the knuckle is removed from a vehicle with all of the parts still on it, then all of the threads and machined surfaces should be in good shape.
P.S. Your spell checker made your post a funny read. LOL e.g. "break cailber" instead of "brake caliper."
Old Oct 5, 2018 | 09:43 AM
kallen90's Avatar
It might not be the best fix but it will work for a few weeks until I find a knuckle and replace all the brake components in the front (I just finished rebuilding the front end in terms of suspension and steering). I'm a full time college student, husband and worker, trying to find a used knuckle is a little lower on the list of priorities lol.
The bushing that goes over the bolt that installs into the brake caliper is about 3/4 of an inch, I could see from the the grime line that the caliper didn't slide over the entire bushing. I literately had to shave a hair off of that bushing the get the bolt in just enough to grab some threads. I was able to torque it, the caliper will slide a little closer to the bolt head but not anything noticeable.
Do you think I could pull my knuckles and take them to a machine shop and have them stake a threaded bearing in the knuckle? I don't think they could add metal to the hole and re thread it, there just isn't anything to work with in terms of re threading the hole on the knuckle.
Old Oct 5, 2018 | 10:33 AM
Strangerock's Avatar
Strangerock is on a distinguished road
A reliable fix would be a helicoil repair unless you can find a good used one.
rdbtoasta
Jul 6, 2009 02:25 PM
GregC5
Mar 22, 2009 08:48 PM
95LS
Mar 22, 2009 08:27 PM
stevelknievel
Aug 18, 2007 05:44 PM
AutomagicLS1
Dec 4, 2006 11:54 PM
