Smelling Antifreeze
Old Feb 20, 2007 | 10:05 PM
Brian J. Lesko's Avatar
Brian J. Lesko is an unknown quantity at this point
Default Smelling Antifreeze
I am catching a slight antifreeze smell whenever I exit my vehicle. It's a 94 4.3 Vortec. I can't find any wet spots anywhere on the engine or hoses, no steam is coming from the engine, and no spot of antifreeze is on my garage floor. I've been keeping an eye on the coolant level for a few weeks now, and it hasn't dropped. I must have a very small leak. About a year ago I completely flushed the entire coolant system and replaced the thermostat. Does anyone have any ideas as to where I might be leaking coolant? The truck is plagued by a slight rough idle. I don't know if a leaking head gasket may be the cause of the antifreeze smell and the rough idle or not. By the way, I just changed oil last weekend, and there is no coolant in the oil. Thanks for any help you can give me.
Old Feb 21, 2007 | 12:04 AM
Kordog's Avatar
Kordog is an unknown quantity at this point
Default RE: Smelling Antifreeze
I have replaced my fair share of intake gaskets on these engines, in fact I just did another today. Usually they will leak at the corners. Korey
Old Feb 21, 2007 | 10:24 AM
guywm25's Avatar
guywm25 is an unknown quantity at this point
I too, have the same problem and symptoms as you, mine is the intake gasket, the leak just gets worse, there is some excellent links for repair on this site. the estimated time of repair on the links is 5-6 hours. so good luck. I am going through a gallon of mix every 4 days.
Old Feb 21, 2007 | 10:31 AM
Wow, that is quite the leak guywm25! You are going to want to get that repaired ASAP!!
I have the leaky intake manifold as well, but mine is leaking out, not in and only enough so that I can smell it. It doesn't really even keep the leak area wet at all times either. I'll put a splash of coolant in every 3-4 weeks. Once it gets warmer out and I start driving my Bonneville again, I'll tear it apart and get it replaced. I already have all of the gaskets and everything necessary, just don't want to deal with it in the cold.
Old Feb 21, 2007 | 09:40 PM
pilgrim's Avatar
pilgrim is an unknown quantity at this point
Chances are that it's intake manifold gasket if you smell it outside, or a small leak in the heater core if you smell it inside.
I posted a procedure for replacing the intake manifold gaskets in the DIY section. If the leak is emptying outside the motor, you can put off messing with it. If it leaks into the motor oil, then the oil will get grey and frothy and you must fix it or park the vehicle.
DO NOT believe 5-6 hours for intake manifold gasket replacement. The first one took me 20+ hours, and I've been working on cars for 30 years. Next time I can probably cut that to 10-15 hours.
Old Feb 21, 2007 | 11:02 PM
Kordog's Avatar
The intake is so a 5-6 hour job for the do-it yourselfer. I just did one on a 92 with the cpi motor in about 2.5 hours. Brian this is the same one you have. What makes this intake nicer than the '96 and newer ones is that you don't need to pull the compressor and the bracket off the front of the engine. It is just removing the upper intake, the dist, and then the lower comes off. Of course this is the extremly condensed version. The parts I don't like about this job is fighting with the fuel lines, and the gaskets don't have locating pins and they like to slide around a bit. And then don't forget to set the timing. Korey.
Old Feb 23, 2007 | 12:01 AM
Thanks for everyone's input. I'm going to see what I can come up with over the weekend. I will keep everyone posted. Thanks again.
Old Feb 23, 2007 | 05:48 PM
s15kid's Avatar
s15kid is an unknown quantity at this point
This may sound goofy, but before you go through all the effort of the intake, have your battery checked. A battery going bad can smell like antifreeze. Don't know why but they can.
Old Feb 23, 2007 | 11:10 PM
The battery is less than a year old, but I'll check that out.
DucatiKoenig
14
Dec 21, 2009 10:25 PM
BrokenBlazr
Jan 15, 2009 06:55 AM
bksowers1
Nov 27, 2008 05:36 PM
rustyd
Sep 15, 2007 10:50 PM
blazered
May 14, 2007 10:42 AM
