thermostat??
RE: thermostat??
My previous post was more aimed at eddiegreeny.
If you were low on coolant, that could expain the differences. With a stock 195*F stat, your engine temps should be 200-210*F. 190*F is within the realm of the inaccurate factory gauge.
Base on your post above, sounds like things are working correctly.
RE: thermostat??
aight thanks everyone!
RE: thermostat??
It's not so much the quality of the engineering...engineers don't make a ton of money for nothing..but companies increase their tolerance levels in production, and use lower cost materials. That's why you can buy a thermostat for $8.
The t-stat on my Range Rover is one of the few things that won't fail...those suckers are the size of a baseball and run $80 each! Now if only Land Rover will use those production specs on their electrical system....
RE: thermostat??
what if your needle for the thermostat isnt moving even after having it run for an hour?
Weshard
10-28-2005 01:26 PM
CKSMartin
02-24-2005 02:39 PM
