Towing question
Old Jan 29, 2007 | 08:18 PM
rfiglia's Avatar
rfiglia is an unknown quantity at this point
Default Towing question
I have a question , I need a truck to tow my 17ft boat. The whole set up,Boat,Motor and trailer weight about 2000 lbs. Someone locally is selling a 93 S10 Blazer Tahoe LT 4WD with V6 with 105k miles. Can this tow my boat without putting to much strain on the tranny ? I want to use it for my daily driver also, what kind of MPG on the hwy can I expect without towing? Can I use reg. unleaded? Thanks.....Rich
Old Jan 29, 2007 | 09:52 PM
nofear17bmx's Avatar
nofear17bmx is an unknown quantity at this point
Default RE: Towing question
This is all best guess, but I would be realisticly guess you would get about 13-18mpg depending on how you drive. That truck can tow a 2,000lb boat just fine, but like I think anyone on this forum would suggest is that you put the truck in 3rd when towing somthing of that weight. Also people may suggest that you get a tranny cooler other then the one that runs into your radiator. Good rule to go by is dont try to tow anything more then 3/4 the weight of your vehicle. However I did know a guy who towed his work trailer with a chevy blazer beater that weighed 4500lbs he claimed. So these blazers are pretty tough.
Old Jan 29, 2007 | 11:12 PM
user 1016's Avatar
user 1016 has a spectacular aura aboutuser 1016 has a spectacular aura about
I pulled a 6x12 u haul trailer completly filled..and I mean filled with furniture and other stuff...I don't know the exact weight...I have just the standard hitch...and a 2000 blazer...4 door...I had no issues pulling the trailer twice 500 miles in both directions...however....it does take it's toll on your truck...and if you have a lot of hills and steep terrain to do something to make sure your trannie stays happy..I lost heat for a bit after the last time I pulled the trailer...and as for gas millage..I have found with my truck...pulling or having a bulky load (like canoes etc..) doesn't affect the gas milage much on these blazers..my gas milage dropped from 18-20 on highway..to about 16....but I am sure there are other people who would have more facts on the whole towing thing...
Old Jan 30, 2007 | 12:59 AM
Kordog's Avatar
Kordog is an unknown quantity at this point
I pull my 2000 lb pop-up camper with mine with no problems. I keep it in OD even!! I just shift to 3rd if the trans starts to get busy. I get about 16.5 mpg normally, and with the camper attached I get about 14. This year I am adding a trans cooler and I just finished my trans temp gauge install today. I use Lube gaurd in my trans and I put a drain plug in the pan so I change the fluid every 12,000 miles and the filter every 24,000 miles. This keeps my fluid looking GREAT!!! It looks as though I have a brand new trans. The most important thing to keep in mind is keep it cool!! These transmissions (like all autos) HATE HEAT. Keep em cool. Korey.
blazerJim1701
Jul 27, 2009 11:30 AM
2000Blazerzr2Can
Jun 14, 2009 01:04 PM
VickiC1994
Jul 15, 2008 09:25 AM
jeff6898
Jun 15, 2008 06:21 PM
gserve
Suspension Tech
Mar 4, 2007 11:36 PM
