transmission questions
i bought a 91 blazer its got floor shift for four wheel drive. well my trans lost third gear it just slips then it trys to shift from second to third so i bought a rebuild trans from a guy, turns out it is electronic shift from out of a 92.....can i just change the transfer case's or is it a different trans altogether ??? i would greatly appreciate ur input....thanks
What is electric shift?? If the transmission is the 4L60E (electronic version of the 4L60), then you cannot use that transmission.
But if it's from a '92, it should not be a 4L60E. Are you asking about pushbutton 4x4 shift vs. your lever shift?
In other words, did you buy a transmission and transfer case still mated together? If so, just leave your transfer case installed and swap the trannies.
I figured that should be fairly obvious that the transfer case should remain. Just trying to get clarification. No saying that it was definitely a 92 tranny.
he said it was out of a 92 ya im talking about the pushbutton 4x4 ill get some pics and numbers of the trany i got another one and put it in last night but i would like to find out what this one came out of maybe u guys can help me??
If it has a large electrical connection on the driver side of the transmission about 2/3rds of the way back from the front of the pan, then it is a 4L60E.
i beleave its on the passenger side now and hes saying it out of a 93
If it's from a '93, it's a 4L60E.
here are some pics i just want to make sure i know whats its out of so im not ripping someone off thanks a lot guys
http://i100.photobucket.com/albums/m...e/P1020432.jpg
http://i100.photobucket.com/albums/m...e/P1020435.jpg
http://i100.photobucket.com/albums/m...e/P1020433.jpg
mcatnova
10-07-2010 09:08 AM
Patrick_Boyle
09-26-2010 05:37 AM
vankuen
09-22-2007 05:26 PM
