using a paperclip in 1994 4.3 w S-10
Old Jan 23, 2015 | 03:24 PM
wanderlust2's Avatar
wanderlust2 is on a distinguished road
Default using a paperclip in 1994 4.3 w S-10
The check engine light on in my 1994 4x4 S-10 4.3 w auto and I've read conflictive reports about using a jumper (a paperclip) because the 94/95 models were different. The connector on mine is of the 12 pin design. The engine starts fine but idles rough. An Actron CP9145 scanner supposedly works but I can't find one. So if any 1994 owners have info on this I would appreciate your replies.
Old Jan 24, 2015 | 10:11 AM
ussexplorer's Avatar
ussexplorer is on a distinguished road
Default Hmmmm
12 pin is correct for chevy pre-odb II connector. If this works. The link below shows you both types and you jump B & A with ignition off. Then turn on but don't start. Then the check engine light should flash a code.
https://search.yahoo.com/search;_ylt...yfp-t-901&fp=1
Josh
Old Feb 2, 2015 | 03:31 PM
chris015's Avatar
It'll work.my 94 did. Top far right 2 prongs. Dont start it with the clip in.
toadfrogjr
Nov 10, 2009 09:09 AM
88s10Blazer
Jun 20, 2006 05:56 AM
jagblazer01
Feb 27, 2006 03:03 PM
shaka1111
Feb 13, 2006 02:23 PM
Bojib
Dec 9, 2005 08:48 PM
