weird turn signal/brake issue
Old Dec 28, 2008 | 01:13 AM
KSEScream420's Avatar
KSEScream420 is an unknown quantity at this point
Default weird turn signal/brake issue
sorry if this has been posted before, i looked and couldn't find anything all too helpful.
I have a 91 s10 Blazer 2wd, my left turn signal and brake light is fine, the right one however is not. When the headlights/parking lights are on the right turn signal light on the dash is lit when i flip the turnsignal it does not blink. if the head/parking lights are off it will blink on the dash and in the front, but not in back. and the brake light isn't working on that side either. Any suggestions at all would be appreciated.
My buddy told me something about the pigtail assembly...any merit to this?
Old Dec 29, 2008 | 11:16 PM
daroach1's Avatar
daroach1 is an unknown quantity at this point
Default RE: weird turn signal/brake issue
I had a problem with my front driver side just like that. I cleaned the wire contacts and the rim of the hole that you place your bulb through. Fixed my problem. I was told that the rim acts kind of like a ground.
Old Dec 31, 2008 | 09:24 AM
AHA! my thanks to you roach, there was a **** ton of bulb grease in the bottom of the socket, stuck a q-tip in there and cleaned it out and works perfect. Thanks Alot!
SubbinBlazer
May 24, 2013 12:56 PM
drummerdude
Dec 17, 2009 09:55 PM
ta3ff
Oct 14, 2009 05:07 PM
rryker
Apr 25, 2006 04:14 PM
shaka1111
Feb 13, 2006 02:23 PM
