What is normal oil level?
Old Nov 22, 2011 | 12:29 AM
408blazer's Avatar
408blazer is on a distinguished road
Default What is normal oil level?
hello,
i just purchased a 1994 blazer 4x4 a few days ago. I have never owned a a chevy before so im still getting used to everything.
My questions is:
what is considered normal oil level? is it at 40 or 80?
also when i step on the gas my oil gauge rises up, but when i slow down the gauge drops down. is that normal?
thanks for your help.
Old Nov 22, 2011 | 01:07 AM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
the pressure going up and down with increase of rpm is perfectly normal. and what do you mean by oil level at 40 or 80? are you talking about the numbers on your oil gauge? If so that would be your oil pressure, and 20 at idle is alright and when you step on the gas it should be in between 40 and 80
Old Nov 22, 2011 | 08:25 AM
chris015's Avatar
these engines only need 6 psi per 1000 rpm at bare minimum. Idealy if its above 20 at idle,and around 40 cruising your fine. Mine has over 200k miles and im still at 40 psi at idle.
and yes it will move when you drive etc.
Old Nov 22, 2011 | 12:05 PM
ChevyBlazerChick's Avatar
Yup, what those two said
Old Nov 22, 2011 | 10:53 PM
408blazer's Avatar
Thanks for the help guys, that makes feel better.
I'm really starting to like this truck and look forward to learn more about them and contribute with what I can here.
Old Nov 25, 2011 | 06:40 PM
bertrenolds's Avatar
bertrenolds has a little shameless behavior in the past
Oh don't you worry, if it's a 94 vortec engine you will be learing lots about it. Mainly how to take the plenum off and replace the spider injector. It's only a matter of time And use a torque wrench when you put the plenum back on. And your ball joints and tie rods are probably in need of replacement unless the previous owner did it for you.
TheNasty0ne
Dec 7, 2010 03:23 PM
bulldogauto
Jun 11, 2010 07:43 PM
Tony H
Oct 26, 2009 07:19 AM
4x4blazerguy
May 17, 2008 01:33 PM
nofear17bmx
Dec 22, 2006 04:38 AM
