[electrical][AC] Blower motor question
So my ac is constently blowing fuses so I test the continuity and found 2 pins that give me a beep I took a picture of it but its the plug that plugs in the blower motor. Kinda knew to car repair and everything so was just trying to work through it myself. The ac will run for a while then blow the 20amp fuse in the side of the dash. I found a total of 3 plugs that plug into the main ac system then like 2 into the blower motor section.
Would that be all the plugs that I would check for??
I attached the pictures below, if you guys have anyother input or some guess i can take more pictures and even a video if you would like. Let me know and thanks everyone for your help and knowledge!!!
What is the year and model? Manual HVAC, not automatic climate control, is that correct? The first & second images are the blower motor resistor. The third one is the clutch cycling switch. What number is next to the fuse in the fuse panel? Does the blower stop working or does the compressor clutch stop engaging?
The fuse is the ac compressor fuse 10amp fuse.
the first picture shows the arrows of the 2 points i checked with the multimeter that im guessing that the short is comming from causing the fuse to blow but not totally sure.
thanks for the help captain
In your images, the plug with 4 wires is for the blower resistor. Totally seperate circuit from the A/C clutch, (that's not the problem).
Automatic climate control has degree markings around the temperature selector dial, manual HVAC does not.
Unplug the A/C compressor clutch electrical connector located right next to the compressor pulley. The connector has two wires: dark green and black. Make sure the fuse is good. Turn the mode switch to MAX A/C, and drive the vehicle. See if the fuse blows. If it does not, the clutch field is shorted and needs replacement. Post your results.
maxvamp
10-31-2020 08:19 AM
XIonRAILS
01-22-2014 10:41 PM
DaveRush
10-12-2011 11:10 PM
SWATPARAMEDIC
01-01-2010 03:12 PM
