95 blazer OBD1.5 :( need help with paperclip jump
I tried searching and get many conflicting reports. It has the the OBD1 sticker in the engine bay but I have a 16 pin port under the dash. My engine light is on and MPG is horrible. I want to get code but do not know how to. I have OBD2 scanners and they obv cannot help. Autozone+O'Reilly says they cant do it either
The 16pin port has the following pins: 2,4,5,9,13,16
I just need to know which two to jump to get the code from the dash. Thanks!
Good luck
Looked it up - it was the Actron CP9145 that is reported to work on your vehicle. It's not made any more, so used is the only way to get one. It is a simple scanner and it is used on both OBD1 and OBD2 vehicles. Make sure you get the adapter cables that you need to hook to your vehicle. I do not have a CP9145 myself, so that is as far as I can get you.
Denominator
13
10-03-2012 08:59 PM
