'97 Engine Compartment Component Identification Needed
Old 05-17-2014, 02:12 PM
adc's Avatar
adc
adc is offline
adc is on a distinguished road
Question '97 Engine Compartment Component Identification Needed
I'm replacing the battery tray in a 1997 4.3 4x4 and under the battery tray is a part that has an electrical connector going to it and a cable routed beneath the truck.
It looks like it might be some type of diaphragm device.
Can someone identify this part?
Thanks.
Al
Old 05-17-2014, 02:22 PM
Sounds like you are describing the front axle actuator for the 4wd. It is not electronic, rather it has a vacuum line that would be routed down to the transfer case vacuum switch for activation. The other end goes down to the front axle.
Old 05-17-2014, 03:11 PM
adc's Avatar
adc
adc is offline
I took a closer look. You are correct.
What I thought was electrical connection protected by split tubing is a good sized vacuum line.
I should have looked a little closer.
Thanks again.
Al
BlackRoseImmortal
01-04-2015 02:44 AM
Striker911
10-29-2012 03:28 PM
GABlazer92
03-24-2008 12:26 AM
nflea7
08-14-2007 12:36 PM
thanser
01-28-2006 08:50 PM
Quick Reply: '97 Engine Compartment Component Identification Needed
