changed the fuse and still doesn't work.
My service engine soon light is on, I have a 98 Chevy Blazer LS. I took it to see why the light was on in the process I had to change the fuse for the cigarette lighter for them to try and get a reading, well i changed the fuse and the lighter still does not work so they can not do a reading. Anyone know what else i can do to get the lighter to work? Any help will be greatly appreciated.
RE: changed the fuse and still doesn't work.
did you replace it with the right fuse? 15A it has to be, check the AUX power fuse if you have the 2 aux outlets. Also make sure theres nothing down in the outlet that could be blowing it
Yes, I replaced it with a 15A fuse. I think I checked the AUX fuses as well but I will double check
Ok, I have checked the AUX fuse and all other fuses and all are good, so needless to say i am still stumped. Could it be something under the hood in the fuse relay box?
lazer2000
09-16-2012 11:16 PM
zahaeus2005
08-15-2012 07:56 AM
SeanPatrick
06-14-2011 10:56 AM
01blazer1981
06-26-2008 10:57 AM
