Fuel ups difficult
Fuel ups difficult
Have an '01 4Dr. Just bought last week. Went to fill up with fuel. But no matter how you place the fuel nozzle in the tank. It wont take fuel unless it's trickling in.........
tried a different pump also..
Any Ideas????
Thanks,
Dan
Any Ideas????
Thanks,
Dan
RE: Fuel ups difficult
Sounds like your tank is not venting properly. Check your vapor recircualtion lines to make sure they're not blocked. Do the same for your carbon canister, sometimes when the tank is overfilled past its rated capacity (force filled by slowly trickling fuel into the tank) liquid fuel gets into the canister causing a blockage. I believe the canister is located at the back on the left side just behind the left bumper end. One of the recirculation valves could be stuck in the closed position, try tapping the tank from the bottom and sides to release and open. I hope this helps.
j5689
03-27-2010 12:56 AM
snosh
09-28-2009 03:15 PM
Smoked
02-21-2009 03:20 PM
harpes620
12-08-2006 10:07 PM
