MAF corrosion fix
Old 05-07-2009, 11:50 AM
ABN31B's Avatar
Default MAF corrosion fix
I have been poking around the forum for a bit and have been reading up on this Mass Air Flow Sensor cleaning that everyone swears by. I decided to tackle it last night as I had some free time. When I pull the MAF from the air tubes, disconnected her and got to work, I ran into something I had not seen mentioned here.
(Ok from here on out my naming of parts might not be "technical" as I am not "very good with mechanical things". Please bear with me.)
The metal that hugs the MAF guts (imagine a reverse colored oreo with the metal being the cookie part) is pitted and corroded on the inside. I do not know if this can cause/lead to any major problems, but I doubt it was put there by the factory...
My question is this: can I pull the MAF cookie again, remove the cream filling, and polish out the pitting/corrosion with a dremel brush, clean up the shavings, slap it back together, and re-install without deadline-ing my ride?
Old 05-07-2009, 12:16 PM
Sure can.
Old 05-07-2009, 02:08 PM
ABN31B's Avatar
*taps Easy Button*
Thanks swartlkk
Old 05-07-2009, 03:22 PM
Just do not damage the screen! LOL
Old 05-08-2009, 12:12 AM
ABN31B's Avatar
oh no! i pulled the screen and chucked it! i liked the idea of a tornado of air with no way to go :P j/k
Old 05-08-2009, 06:46 AM
LOL
I would leave it at LOL if it were not for the minimum character limit.
sledzepplin
08-15-2015 09:13 PM
warthogdriver
06-28-2012 03:52 PM
richphotos
12-18-2011 05:34 PM
ziggy888
09-05-2010 08:50 AM
vortexflow
11-28-2009 12:34 AM
Quick Reply: MAF corrosion fix
