01 blazer won’t start
Old May 2, 2019 | 04:23 PM
Derrick Santos's Avatar
Derrick Santos is on a distinguished road
Default 01 blazer won’t start
Just picked it up 2 days ago it’s an 01 127k miles broke down thought it was gas filled the tank broke down literally 10 seconds later starts back up but dies out 5/10 seconds in not the alternator fuel pump ?!
Old May 2, 2019 | 05:05 PM
cleburne red's Avatar
Might as well check the fuel pressure. It's a super common problem on these trucks.
Also, and check engine lights? Codes? Got spark?
Old May 2, 2019 | 07:06 PM
will do and no check engine light but I believe all my gauges and maybe even sensors may be bad when it shuts off says check gauges, and I was gunna get it checked out tomorrow first thing
Old May 2, 2019 | 07:22 PM
odat's Avatar
Fuel pressure does not throw codes, check gauges dash light is lit up when key is on and nothing is being read by the computer { oil pressure, voltage ECT. } - it's normal
Old May 3, 2019 | 10:15 AM
Mike.308's Avatar
Do not bother with that right now. If the oil pressure drops down, then it triggers the "check gauges" on. When You shut the engine, You also shut down the oil pump, that is driven by a crankshaft, so the oil pressure drops down. Therefore You my be getting "check gauges" on. And, even if the "check gauges" is on, it will not automatically shut down Your engine. Check the fuel pressure test. It's amongst the sticky topics.
Old May 3, 2019 | 11:37 AM
Like the others said, check guages comes on with the key on, engine off. Don't worry about that. Get your fuel pressure checked, and post the results
alloy
Nov 10, 2013 06:38 PM
limited edition 1
Mar 22, 2011 06:15 PM
bigdawgz2006
Nov 20, 2009 03:47 PM
linje
20
May 22, 2009 06:26 PM
pug817
Apr 18, 2009 09:45 AM
