1995 2 door ECM-B fuse.
Old May 12, 2019 | 07:48 PM
Kusstard's Avatar
Kusstard is on a distinguished road
Default 1995 2 door ECM-B fuse.
Hey guys.
So I have been tearing my hair out for the last year over my ECM-B fuse on my CPI engine. After tracing wiring, looking under the dash for any pinches or shreds, tracing more wiring all the way back to the fuel pump with no luck. The fuse blowing is very intermittent, but was very frequent just today. At this point I’m down to putting a pump in. I will be relocating the ground for the fuel pump tomorrow after work to see if that helps, but after that, it’s time for a pump. I guess my question is, can a bad fuel pump cause a fuse to blow? Or should I pay extra attention to this ground?
Old May 12, 2019 | 08:37 PM
odat's Avatar
Yes too all the above ,,,,,
Old May 12, 2019 | 08:53 PM
Kusstard's Avatar
Thank you, friend, I appreciate it
Old May 13, 2019 | 07:39 AM
GeorgeLG's Avatar
Why are you concerned about the pump ground?
what happens? The truck runs great, stops running and then you see the blown fuse?
George
Old May 13, 2019 | 08:50 AM
Kusstard's Avatar
Precisely George, with no prior warning to speak of
Old May 13, 2019 | 09:07 AM
GeorgeLG's Avatar
George
Old May 13, 2019 | 09:15 AM
Kusstard's Avatar
The last time the fuse blew last night, I messed with the ground wire and it fired right up and didn’t blow the fuse, and still did not this morning. That’s my simple, probably not thorough enough, diagnosis
Old May 13, 2019 | 02:11 PM
Mike.308's Avatar
There are two cases, where one excludes the other. Poor connection increases the resistance and lowers the current. It won't make the fuse blow. Fuses blow, when You're over current.
liljoekrankota
Dec 21, 2012 05:13 PM
dignzepln
Mar 26, 2012 11:11 PM
Blazin420
Feb 11, 2012 09:29 PM
xs2003
Jun 1, 2011 10:46 AM
cmc039
May 28, 2011 09:29 AM
