1997 LT Oil Leak
Old Apr 3, 2014 | 04:30 PM
If that doesn't fix it, the oil filter adapter might be the problem, (the piece that the cooler lines connect to). There's a gasket and an O ring that like to leak on these. If that turns out to be the problem, do yourself a huge favor and replace the oil pump bypass valve while the adapter is off... about $10.
Old Apr 3, 2014 | 07:50 PM
er0ck273's Avatar
er0ck273 is on a distinguished road
Originally Posted by userID-81055
Found my leak finally, going to change my oil and replace the oil cooler lines. Thankfully it wasn't the rear main. Thanks for all your help!
how were you able to tell? like yours, the oils literally everywhere. did you let the truck run and just sit under there? and this might be a dumb question but was it from the fittings? i heard theyre cheap and prone to leak, even the new OEM lines
Old Apr 5, 2014 | 01:35 PM
userID-81055's Avatar
userID-81055 is on a distinguished road
Basically i got it washed out underneath at the carwash. Went home got under while running, located my oil cooler lines and saw the drip. My lines actually got warped due to age thus causing the leak. The new lines seem better because they are new but only time will tell.
Old Apr 6, 2014 | 06:32 PM
er0ck273's Avatar
definitely a good idea, gonna check it right before i change my oil in a month or so
thank you !!
SnowBlaZeR2
Mar 18, 2015 08:58 PM
FireInMe17
Sep 11, 2013 09:54 PM
FireInMe17
Oct 9, 2012 10:53 PM
xillzxnickx
Sep 29, 2012 01:02 AM
SnowBlaZeR2
Jun 26, 2012 11:54 AM
