2000 chevy blazer rough idle
Old Jun 24, 2019 | 09:25 PM
GeorgeLG's Avatar
Originally Posted by Lauriejo
Thank you currently im stuck on screw for distrubtor cap. Whoever worked on it b4 me must have lost the torque screws and replaced them with phillips. But they drilled the hell out of one closest to the engine and rounded it out. i cant get a grip in it with anything to turn it. Idk what to do. I have one of my nail files and have been trying to file it to where i can grip it. But that is slow going. There has to be a better way
I would probably just waste the distr cap and drill through the head of the messed up screw, pull the cap off and then back the threaded post out.
George
Old Jun 25, 2019 | 04:43 PM
Lauriejo's Avatar
Lauriejo is on a distinguished road
Ok i got it out... Are tou suppose to be able to move the rotor just a little bit
Mike.308's Avatar
Follow what GeorgeLG says.
And before You get much into repair, I suggest You make an accurate diagnose. Reading codes plus some live parameters will save You of unnecessary work and expenses. We'll help You sort the things out. First, get the scanner, check if there are any codes and report.
Old Jun 27, 2019 | 12:51 PM
Lauriejo's Avatar
Update. I got screw out on weds but put a hole in cap getting it. Im going to install new cap and rotor. I picked up code reader from my dad. He usually helps me but has been sick lately. Ill run for codes as soon as i get it put back together. Thank you George
Cowboyturner
Feb 22, 2019 09:00 PM
martin2000B
Jul 18, 2011 09:58 PM
1badblaze
Feb 22, 2009 11:29 PM
Canadianblazer97
Jun 10, 2006 09:17 AM
