2001 Blazer engine options
Old Feb 27, 2013 | 12:49 PM
illestdaniel's Avatar
illestdaniel is on a distinguished road
Default 2001 Blazer engine options
Hello,
I recently purchased a 2001 Blazer ZR2 with a blown engine. My question is what year engines will fit my truck? I found a 2004 4.3 out of a silverado and a 2000 4.3 out of a blazer, from what i have read the 2001 has a smaller knock sensor bolt because the sensor is different and the the 2000 has a larger bolt which probably will not work for me any ideas on the 2004? and also how new of a truck can i get the engine out of? will 2007+ work?
Old Feb 27, 2013 | 12:50 PM
Thanks in advance guys!
Old Feb 28, 2013 | 01:40 AM
Bump sorry for the newbie question couldnt find anything online maybe im frasing my search wrong....
Old Mar 1, 2013 | 11:57 AM
This forum is awesome.... 149 views not one reply... Thanks.
Old Mar 17, 2013 | 03:50 PM
Webb_d's Avatar
Webb_d is on a distinguished road
Hey I'm having the same problem i have a 2001 blazer and replaced the engine with a 1999 engine and I'm running without the knock sensor does not affect the driving but I have a constant check engine light on and I need to do a state inspection next week.....I'm trying to find a solution for this but there's nothing online so I'll be following your post closely.. Good luck
Old Mar 17, 2013 | 04:22 PM
coolasice's Avatar
coolasice will become famous soon enough
ok.. you have a few options... you could go with a reman longblock.. that will fit no modification necessary. if you want to use the silverado engine, you will probably have to swap the oil pan, lower intake manifold, and exhaust manifolds from your original to it and you will also have to drill out the knock sensor hole and tap it to a larger size for your current knock sensor to fit.
Last edited by coolasice; Mar 17, 2013 at 04:33 PM. Reason: grammer.. i whent 2 skool
Old Mar 18, 2013 | 07:32 AM
midnightbluS10's Avatar
midnightbluS10 can only hope to improve
2008+ engines aren't an option. They use a different ignition system that doesn't use a distributor and they use a different ecm as well.
The 04 4.3 should work fine as long as you swap your parts onto it(oil pan, exhaust man, int man, etc...). It comes with upgraded mpfi injectors, also, instead of the central injector and poppet nozzles.
tenorsaxdude
Jun 2, 2014 02:43 PM
jimmyeatworld
Apr 15, 2008 08:06 PM
revisednut
Jan 29, 2008 10:11 PM
94BlazerFORSALE
Engine & Internal
Nov 13, 2006 12:36 AM
rcravincase
Engine & Internal
Jul 5, 2006 08:14 AM
