2001 blazer hard to start
I have a 2001 chevy blazer , If I do not start it every 10 - 12 hours it is hard to start . Once it starts first time , it starts fine the rest of the day. Weather does not change how it cranks. I have new tune up, new fuel pump , fuel filter , air cleaner , coil new ,I checked fuel pressure 60 lbs. , new battery , new starter....I'm out of ides.....PLEASE HELP !!!....I have 60 lbs pressure, cold , hot ... Pressure remains 60 even after I turn the key off ... I check the pressure at the fuel rail, that is after the fuel filter...I disconnected the fuel line after the fuel filter plenty of fuel...When it is not starting I can smell raw gas fumes...It is turning over normal....not slow...
Last edited by Robert Lee Hicks; 11-18-2013 at 03:05 PM. Reason: more things I have changed
Guest
Posts: n/a
It's almost always the same thing to start with on these things. The fuel pressure leak down test. With the key on engine off it needs to hit at least 60 then not go below 55 in ten min. If it drops faster then that there's a problem. Most often pump is failing but second most common is injector problems.
Do that test and come back with results. If it's not good to be absolutely positive it's not the pump you will need to do the same test from the filter.
You cane take of the plenum and inspect for obvious leaks, you will see shiny gold areas and not the consistent carbon crudded up look.
All you really need to do this is a deep socket 10mm and about an hour.
The part underneath the rotor is the camshaft position sensor. Even if it's unplugged, it can not cause a no start condition. If it starts and runs now, rest assured it was a faulty distributor cap and or rotor. Glad you got her going.
Kevin Gore
12-13-2013 09:35 PM
dubaholic2
05-24-2011 12:44 PM
ejxjohnson
09-10-2010 08:21 PM
