2001 blazer v6 hard to start
Old Oct 8, 2012 | 07:11 PM
sailorjohn's Avatar
sailorjohn is on a distinguished road
Default 2001 blazer v6 hard to start
My blazer is hard to start but once started it runs great. when I try to start it after sitting all night it will crank but not start. If I repeat this 5 or so times it will start. If I drive it somewhere then turn it off and it sits for a short time and then try to restart it it starts and runs fine.
Any ideas?
Thanks in advance
John
Old Oct 8, 2012 | 07:29 PM
4x4blazerguy's Avatar
John,
I had an issue just like this & it turned out to be the Fuel pressure regulator. But to check you should do a bleed down test. Also a pressure check. There are test procedures on this site use your search.
Old Oct 9, 2012 | 10:19 AM
sailorjohn's Avatar
Default 2001 hard start blaser
Thanks for the reply. I will check the fuel pressure, I suspect you are correct.
Thanks again for the reply.
John
Robert Lee Hicks
Apr 24, 2014 07:59 PM
Kevin Gore
Dec 13, 2013 09:35 PM
dubaholic2
May 24, 2011 12:44 PM
ejxjohnson
Sep 10, 2010 08:21 PM
mnsajt
Apr 20, 2008 02:55 PM
