2005 Jimmy not switching in/out of 4WD
Old Jun 24, 2008 | 11:58 AM
ninepointer's Avatar
ninepointer is an unknown quantity at this point
Default 2005 Jimmy not switching in/out of 4WD
My 2005 Jimmy will not reliably switch in/out of 2-hi/4-hi. Sometimes it works fine, sometimes I hearit buzz-click but need to push the button a second time, sometimes I get blinking lights and sometimes nothing happens at all.
My relative (licensed mechanic) replaced the electic motor found under the vehicle, but the problem seems to be in the multi-wire plug that is located to the right of the front passenger's feet, behind the plastic panel. I'm told that the tiny spring-loaded contacts in the plug are prone to over-heating, curling back and losing contact. When the 2WD/4WD acts up, the solution is to un-plug/re-plug and/or wiggle the plug. This gets things working every time, that is until the next time it acts up again!!!!
Anybody have any suggestions... please....? Thanks!
Old Jun 24, 2008 | 12:00 PM
Default RE: 2005 Jimmy not switching in/out of 4WD
So you remove the connection to the relay and it fixes the problem? Could you snap a picture of the component you are disconnecting?
jasondis
Dec 30, 2012 10:40 PM
ninepointer
Jul 30, 2009 10:03 AM
waterskier98
Mar 4, 2009 03:15 PM
14Blazer88
Feb 6, 2009 11:54 AM
