4wd Hub/Bearing Assembly Replacement
Just to clear something up... The hub assembly is $184 at pepboys. The hub bearings are only $16 and $18 for inner and outer, respectively. If all you need are the bearings then going this way woul be much cheeper.
The difference is 4wd vs 2wd. You cannot just replace the bearings in the 4wd hub/bearing assembly. The $16 & $18 price quotes are for the 2wd spindle inner and outer bearings, not for a 4wd.
ORIGINAL: swartlkk
samurai_24
Oct 2, 2009 12:39 PM
bigrackhunter50
Apr 11, 2007 01:08 AM
