4wd ticking
Old 03-04-2011, 07:40 PM
jjnemoiii's Avatar
jjnemoiii is on a distinguished road
Default 4wd ticking
2001 Blazer will switch in to 4wd and back to 2wd when I push the button to do so, and the light stops flashing which leads me to believe it gets to 4 and back to 2. When in 4wd, I hear a ticking noise from front passenger side, increases with speed, like a playing card in your bike wheel spokes. I've tried several times, same result. Will not try again unless I get stuck, dont want to cause more damage. Any ideas what to suspect or check?
Thank You!!
Old 03-04-2011, 07:46 PM
Your front axle isn't engaging all the way.
This thread talks about that:
4wd Front Axle Clicking When in 2HI - Goes Away when in 4HI/4LO
Old 03-04-2011, 11:17 PM
jjnemoiii's Avatar
Swartlkk, thanks for all the help. Much more than I ever could have asked for, will investigate asap.
Old 03-06-2011, 01:42 PM
BigMac's Avatar
BigMac is on a distinguished road
check all the fluid levels. the front differential fluid and transfer case fluids but kinda sound like the axle engaging problem...
pmezo
27
06-07-2020 04:46 AM
maty98blazer
02-16-2011 01:25 PM
S10Blazer
01-13-2010 02:12 AM
willtoskie
01-10-2010 04:56 PM
low
06-25-2005 04:52 AM
Quick Reply: 4wd ticking
