4x4
I have a 1997 gmc jimmy and when i try to put it in 4 wheel sometimes the light just blinks and does nothing and sometimes it pops tons of fuses now it only goes in 4 wheel lo. any Help or Ideas
I thought I had an issue this week with mine not engaging properly.
Try these: https://blazerforum.com/forum/tech-a...2hi-4hi-40695/
And check this blog out I thought the write up was good info!
'03 Chevy Blazer -- where's my 4 wheel drive? (UPDATED) | KyleStubbins.com
Hopefully you can track it down and it's an easy fix.
What fuses are blowing? With that information, we can dig into the wiring and maybe figure out the cause.
The 4WD fuse (#19 - 20A) supplies power to the +12V motor feed inputs to the TCCM (transfer case control module) and then on out to the encoder motor itself. I would test the wiring from the fuse to the TCCM & from the TCCM out to the encoder motor for shorts to ground. Test it while moving the connectors & harnesses around.
Check out the link below for the schematics:
Please help. 4 wheel drive issue
Manteray
10-02-2011 11:53 AM
razman
02-22-2009 01:57 PM
tolleyc
07-29-2007 05:57 PM
