4x4 Low Help
Old Nov 14, 2007 | 03:12 PM
BlackBlaze's Avatar
BlackBlaze is an unknown quantity at this point
Default 4x4 Low Help
i have a '99 blazer with 44k miles on it and when i was doing a little wheeling the other weekend and the 4 wheel low made a clunk when i engaged it and then it was very jerky when i was climbing. i would appriciate any help. thanks.
Old Nov 14, 2007 | 07:46 PM
user 1016's Avatar
user 1016 has a spectacular aura aboutuser 1016 has a spectacular aura about
Default RE: 4x4 Low Help
the clunk is normal...as far as the jerkieness....it is a little jerky when you step on the accelerator..it's cause of the gear ratio...one of the other guys on here could probably explain why....but it sounds like your truck is just fine...for 4 low
Old Nov 15, 2007 | 01:17 AM
Chevy Lover's Avatar
What you have described sounds fairly normal. Just remember that whem you engage 4L that you should be stopped or travelling less than 5 mph.
Old Nov 17, 2007 | 08:58 AM
quinnman105's Avatar
quinnman105 is an unknown quantity at this point
Question: Sometimes when I start my blazer it goes into 4x4 LO. Then it's a pain in the A** to get it to go back into 2wd HI. Does anybody have any ideas as to why this could be happening sometimes. I'm not sure if my 4x4 HI is working. Is there anything I can check or do to see why this is happening?
Kevin
Quinnman105
Old Nov 17, 2007 | 09:31 AM
blazinloud's Avatar
ORIGINAL: Chevy Lover
and in neutral
Old Nov 17, 2007 | 10:13 AM
I'm NOTusing 4wd LO. When I start the truck it goes into 4wd LO. How can this problem be fixed if I do have something wrong with the truck Is there a way I can see if my 4wd Hi is working correctly
Old Nov 21, 2007 | 09:52 AM
BlackBlaze's Avatar
thanks for the help it just made me a little nervous
jdiaz
Sep 26, 2023 11:29 PM
Streetracer94
Oct 29, 2018 09:33 AM
LioNiNoiL
Aug 4, 2011 02:47 AM
blazergeek1775
Dec 18, 2010 03:14 PM
hitechracing
Sep 6, 2009 01:00 PM
