95 blazer rough idle
Old 02-22-2009, 10:18 PM
1badblaze's Avatar
1badblaze is an unknown quantity at this point
Default 95 blazer rough idle
i have a junkyard motor in my blazer and it has a rough idle but no cel. should it be smooth at idle as i know it has a balance shaft. im worried the valve guides are bad as the last motor had oval shaped guides when i tore them down. it has new plugs and wires. new cpi spider and pump. and a new cap. unknown on the rotor as it was with the junkyard motor. is this 4.3 known for vibratioor what ns
Old 02-22-2009, 11:29 PM
SockJock's Avatar
SockJock is an unknown quantity at this point
Default RE: 95 blazer rough idle
It should idle pretty smooth. You may have a worn distributor gear, stretched timing chain or other issues. Hard to say without doing complete diagnostics. No error codes doesn't necessarily mean everything is working right.
blazerguy22
11-14-2013 11:50 PM
blazer chris
12-08-2011 09:56 AM
nhguy261
12-30-2010 01:41 PM
97BLAZE4X4
02-07-2010 07:33 PM
c10jm
08-12-2008 05:34 PM
Quick Reply: 95 blazer rough idle
