96 blazer won't turn over
Old May 20, 2011 | 12:10 AM
pmezo's Avatar
pmezo is an unknown quantity at this point
Default 96 blazer won't turn over
So I recently tried starting my 96 blazer and I can't get it to start over. It makes the typical start up noise like it always does (not like it would if the battery was dead or dying), but it just won't turn over.
The terminals are tightened nice and snug. The alternator is good. I tried jumping the car and it makes a strong attempt to turn over but never actually does.
Any idea?
Old May 20, 2011 | 12:29 AM
wrenchturner3529's Avatar
wrenchturner3529 is on a distinguished road
By strong attempt to turn over do you mean it cranks but will not start (run)?
Possible fuel pump problem, when you turn the key to the on position do you here the electric fuel pump "whining" as it pressurizes the system?
Old May 20, 2011 | 12:34 AM
pmezo's Avatar
I mean it makes a very strong attempt to start... it just won't turn over and fully start, so yeah, it gives a very strong crank attempt.
When I turn the car in the on position, I do hear that motorized whining noise coming from the fuel pump.
Also, no CEL codes are being thrown.
Old May 20, 2011 | 12:50 AM
Have you check the ECM BAT fuse? Second thought probably not blown as the pump works and turns over.
Old May 20, 2011 | 01:04 AM
pmezo's Avatar
Just checked... it's fine.
Old May 20, 2011 | 01:36 AM
Possible coil, ignition module or fuel pump pressure issue. here's a link that may help. https://blazerforum.com/forum/engine...not-run-45944/
Old May 20, 2011 | 12:32 PM
pmezo's Avatar
I know it's probably not the best way to do diagnostic testing, but I just sprayed some starting fluid in the intake and still no start. Strong crank, but won't turn over.
I'm guessing I must have a ignition or spark problem since the starting fluid won't get it...?
Old May 20, 2011 | 12:48 PM
That just tells you that it wasn't a lean condition causing the no start. It doesn't rule out a rich condition or no-spark condition.
Have you checked out the Tech Article (DIY) section, specifically either of these posts:
Engine Cranks But Does Not Run
No-Start - Engine Cranks OK - Ignition System Diagnosis
amp042
Jun 9, 2013 04:29 AM
bill62
Jan 30, 2010 06:42 PM
mkemu80
Jan 8, 2010 08:25 PM
C@rpaholic
Oct 2, 2009 12:18 PM
PawNtheSandman
Engine & Internal
23
Aug 27, 2006 11:22 PM
