99 s10 blazer wont start need help!
Old Apr 10, 2014 | 08:30 PM
glass385's Avatar
glass385 is on a distinguished road
Default 99 s10 blazer wont start need help!
i was driving somewhere and all the sudden my engine died. i tried to start it back up and all it did was crank and back fire. wouldnt start. so i thought it might have been somethin with the fuel system. it wasnt. then i thought it wasn't gettin spark so i changed the spark plugs and nothing. now its just clicking at me when i try to start it. we tryed and jump start it that and all it did was crank no start. please help me. and thank you.
Old Apr 11, 2014 | 09:29 PM
Backfire through the throttle body while cranking is a classic symptom of a faulty distributor cap & rotor. Use AC Delco only.
Old Apr 12, 2014 | 02:24 PM
Lancealot's Avatar
Lancealot is on a distinguished road
Because it suddenly died I would lean toward fuel pump first. Listen for the fuel pump to cycle for about 2 seconds when you turn the key to run but not to start. If you hear it run check the pressure or even if you cant here it. If your outside with noise and the bell chime sounding sometimes its difficult to hear. Backfire could also be a ruptured fuel pressure regulator leaking fuel into areas in the wrong place at the wrong time. If your not getting spark you may not be getting a signal to fire the injectors either. That could be Crank sensor. When they start to fail Ive seen them stop working when the car is hot or outside temp is hot and work flawlessly when cold. Thats if it didn't just completely fail. Start with trouble shooting the fuel system then if its ok move on to the ignition. If it continues to backfire when your cranking, stop. Find the problem. Something will get damaged. Good Luck.
Old Apr 12, 2014 | 03:52 PM
spittybays
Guest
Posts: n/a
Sudden fail is sudden broke. Timing problem is backfire, if you can, like Chuck said inspect all parts related to your cap, rotor and distributor.
Something is busted up there or down at the bottom of the dizzy.
Old Apr 12, 2014 | 08:17 PM
Yup, induction occurs, (backfire through the intake) if the spark plug fires when the intake valve is open. Crossfire in the distributor cap is usually the cause.
93 nightmare
Jan 26, 2014 02:17 AM
dj00140
May 20, 2013 06:37 PM
1992S10blazer4.3
Jan 29, 2010 08:35 PM
chitowncruiser
Nov 28, 2009 08:03 PM
paulierizzo
Jan 18, 2007 10:36 AM
