ABS light/speedometer/shifting problem
My ABS light came on but everything seemed to drive fine. Then a brake light flickered for a second and I lost my speedometer and Blazer wouldn't shift into higher gears. ABS light turns off after Blazer has been restarted. Would this be a VSS issue as I read it controls ABS and speedometer? If so is this the correct on for a 2002 LS 4x4 4.3L?
Expensive version? https://shop.advanceautoparts.com/p/...310/18481043-P
Cheaper version?
Cheaper version?
I went on vacation and was excited to get home and put in my new VSS. Turns out I use this VSS not the one I bought .
I'm going to order it today. I was praying if I cleaned the sensor off and checked the wires it would magically work. On the way into work this morning the Blazer acted up . Should I order the AC Delco or get a BWD from Advanced today? I've always put AC part pack in but I can get the BWD today for the same price.
elgemcdlf
09-03-2013 06:13 PM
lionel2
03-21-2011 01:55 PM
max1995
12-06-2010 08:24 PM
