AC Delco plugs- what's the diff?
Old Feb 24, 2014 | 02:06 PM
RandyRhoadsFan82's Avatar
RandyRhoadsFan82 is on a distinguished road
Default AC Delco plugs- what's the diff?
Alright guys, so here is my question.
I'm looking at a couple different AC Delco spark plugs, I went to their website and searched all the plugs compatible with my '99 GMC Jimmy. There were a bunch of plugs that all looked the same (except different color metals) and were all listed as "Professional Iridium Plugs". Here are the part numbers:
41-943
41-948
41-950
41-963
41-993
What exactly is the difference between these, if any? Are they just upgraded versions as the numbers rise? I'm looking to buy 6 of one of these part numbers just to give my ride a tune up. Suggestions?
Old Feb 24, 2014 | 02:08 PM
01xtreme_chevy's Avatar
01xtreme_chevy is on a distinguished road
Probably different heat ranges.
I think the 4.3l engines 2nd gen. calls for platinum or double platinum. I think the iridium is a more controlled spark...I could be wrong, if I am, I stand corrected.
Old Feb 24, 2014 | 02:59 PM
Differences are the material that the center and ground electrodes are made of. Single Platinum, Double Platinum, Single Iridium, Double Iridium, etc. Originally your '99 Jimmy came with 41-932, the new number is 41-993, (Double Iridium). Platinum doesn't last as long as Iridium.
Old Feb 24, 2014 | 04:40 PM
so would you recommend I put in 41-993 for best performance/life span?
Old Feb 24, 2014 | 05:40 PM
That's top shelf stuff, yes.
Old Mar 6, 2014 | 09:39 PM
so when I go on ebay, i click on the compatibility with my '99 Jimmy SLT and it says its not compatible...(41-993) is this just an error and will it really fit? looks like it would, I just want to make sure.
Old Mar 6, 2014 | 09:45 PM
Gotta be an error. AC Delco 41-932 (double platinum) was original equipment but it was upgraded to AC Delco 41-993 double iridium.
Old Mar 6, 2014 | 10:31 PM
thank you I'll order them now, just wanted to make sure!
Old Jan 10, 2023 | 07:45 AM
oldeerslayer's Avatar
oldeerslayer is an unknown quantity at this point
Angry eBay clones of iridium spark plugs
Be careful where you buy the 41-993. Amazon and eBay are full of super low priced 41-993 iridium spark plugs that are junk imported clones. I'd highly recommend that everyone stay away from those 2 sight when buying auto parts. You never know what you will receive. Stick to Rockauto or another reputable seller. If you look on You Tube there s a bunch of videos on how to determine if the iridium plugs you received are clones. Real ones for example come with a cardboard tip protector while the clones use plastic. Quality of the laser etching is also way better on the real ones. Some clones even have spelling errors on the plugs and boxes. The clones have been know to fail almost immediately. Some had the tip melt off. Wouldn't want that in your cylinders.
BTW 91-432 is no longer manufactured and near impossible to find or ridiculously priced when you do find them.
Old Jan 10, 2023 | 08:10 AM
LesMyer's Avatar
I just use the good old copper spark plugs. R44LTS6 Now on my second set in 70K miles. Only advantage of irridium or platinum is length of service. The copper plugs are actually documented to work better as a spark plug.
Here's just one of many articles that can be found on the subject. https://www.autozone.com/diy/spark-p...the-difference
bigdaddykane93
Dec 18, 2021 12:08 PM
phxjosh
15
Jul 18, 2018 11:16 AM
Dadatone
Aug 24, 2012 09:10 PM
Plasmatic
Nov 8, 2011 04:32 PM
jmaynard
Aug 2, 2010 04:08 PM
