Actuator cable 4*4
Old Dec 12, 2011 | 01:08 PM
dave39's Avatar
dave39 is on a distinguished road
Default Actuator cable 4*4
Have 96 chevy blazer 4*4 shift on floor for 2*4,4*4 lo hi (NOT ELECTRONIC) Im looking for information or PLEASE possible PICTURE of how the ACTUATOR CABLE ATTATCHES TO THE FRONT AXLE. IT COMES IN SIDEWAYS IN SAME DIRECTION AS AXLE THEN GOES TO ACTUATOR UNDER BATTERY. i SEE THAT THE END THAT GOES IN AXLE HAS A GROOVE AROUND IT AS THE OTHER END THAT HAS THE WEIRD CLIP TO ATTACH TO THE ACTUATOR. SO THE AXLE END HAS A SCREW TO A PLASTIC LIKE HOUSING(LIKE A HOLLOW CONE)WHICH HAS 3 SCREWS TO REMOVE IT.
IM WONDERING WHEN I UNSCREW THE CABLE ON AXLE HOW DOES THE CABLE RELEASE AND THEN HOW DOES IT RECLIP. IN BUFFALO HAVE BEEN DOING THIS STUFF FOR 20+YRS NEVER HAD TO DO THIS NOT TO MENTION HAD 3 HEART ATTACKS AND FIRST KILLED ME AND A MINI STROKE AND SEVERE CARPOTUNNEL SO IM TRIING TO GET R DONE THE EASIEST WAY POSSIBLE. any kNOWLEDGEABLE ADVICE WOULD BE GREATLY APPRECIATED. tHANKS
Old Dec 12, 2011 | 04:15 PM
dave39's Avatar
Default easy fix with pics
this was really so simple look at photo look the cable cost 36 dollars with tax and it connects in the same manner as the valve end just remember to take battery tray and battery out thentake valve bracket out(2 bolts in wheel well front. then take cable off in front then loosen the cable not remove it from the housing take housing off then pull or push tab on clip then remove it the clip stays on so when you put the new one in it clicks itself. Install axle end of cable first then valve end
Attached Thumbnails Actuator cable 4*4-0996b43f8021e2a3actuatorcable.gif   Actuator cable 4*4-0996b43f8021e2a3actuatorcablevalve.gif   Actuator cable 4*4-0996b43f8021e2a3instructionsactuatorcable.jpg   Actuator cable 4*4-0996b43f8021e2a4actuatorcableaxle.gif
Old Dec 12, 2011 | 04:22 PM
xgiovannix12's Avatar
read this it should tell you esactly what to do to change the cable
https://blazerforum.com/forum/attach...ontaxel4x4-pdf
Old Dec 13, 2011 | 09:16 AM
dave39's Avatar
Default dave39
hey thanks for all the info i saved it as you gave me alot more than i needed i figured what i needed out but the info you gave me will definitly be helpful to me as alot of others. Thanks so much
Old Dec 13, 2011 | 02:48 PM
No problem =)
almosta4x4
Apr 17, 2011 08:13 PM
zynnad
Jan 31, 2010 08:03 PM
4x4VegasDan
Nov 26, 2009 11:19 PM
markrd
May 8, 2009 01:39 PM
pmezo
Feb 6, 2009 10:34 AM
