aluminum distributors
Old Mar 18, 2010 | 11:21 PM
blkblazer's Avatar
blkblazer is an unknown quantity at this point
Default aluminum distributors
Any body know of any problems or issues with aluminum distributors.
I guess there is a common problem with the original plastic distributors breaking. Which is my problem. I have allready replaced on distributor due to cracked houseing and I need another one. The first one was not my fault it came with the truck. I was preetty careful not to over tighten cap but it broke any way. Seems that to get the cap on tight the houseing cracks.
thanks
1999 S10 Blazer 2 door LS 4.3L 4x4
Old Mar 19, 2010 | 07:07 AM
If you are cracking the distributor, you are either tightening it too much or you got a bad aftermarket part. GM and many other makes have been using plastic distributor housings for quite some time without issues from the design or materials. It just takes some attention to detail when installing components.
The distributor cap screws only require 21 in-lbs (2.4N-m) of torque. You can easily over torque these bolts with a screw driver let alone using a ratchet.
Old Mar 19, 2010 | 08:13 AM
blkblazer's Avatar
The guy who had the truck before me must have cracked the distrbutor. I put in used one from auto recyclers. It cracked too after about 8 months or so.
Somebody on e bay is advertising aluminum distributors as up grade from plastic distributers that are prone to cracking.
So I will probably buy one to put end to problem. Rock auto has them to. Both are around $100.00 range. Cheaper than Delphi etc.
Maybe bad caps cause the distributor to crack I do not know.
jester429
Feb 1, 2010 01:38 AM
Millertime21
Oct 30, 2008 04:06 PM
dirtdriver85
May 15, 2008 07:23 AM
jimbob533
Oct 4, 2007 11:12 AM
raidersfan
Detailing
May 30, 2006 10:30 PM
