blazer wont stay going
Old May 12, 2009 | 12:11 AM
kmk401's Avatar
kmk401 is on a distinguished road
Question blazer wont stay going
my 97 v6 fwd blazer it got 200sumthing k miles wont stay running i have replaced cap, rotor, plugs, wires, pcv,but it will skip and buck a lil bit when i first get going it smooths out when im good and moving bout half hour 45 mins latter it start having surging and stumbiling and staling problems will die on me and wont turn over but not strt in less i leve to sit for about 20mins then will strt and runn ****y 4 about a min a so also im smelling a light oil and coolent smell when it acts up i dubt that has ne thing to do with ne thing but it not leaking fluids im broke down 3 times to day think the mters done for im cufused and need sum help here sum one pleses know whats going one i relly need your input
Old May 12, 2009 | 12:15 AM
mech cb's Avatar
mech cb is on a distinguished road
Have you pulled your dipstick? Check for a milky residue. Sounds like you blew a head gasket. Just because you don't see a leak doesn't mean its not leaking internally.
Old May 12, 2009 | 02:35 AM
kiwiblazer's Avatar
Welcome.
Old May 12, 2009 | 07:32 AM
*Moved to the 2nd Gen Tech Area* The new member area is for new member introductions.
I would suspect something is amiss with the ignition system or an intermittent fault with the fuel system possibly.
Are there any codes?
Old May 12, 2009 | 11:11 AM
mech cb's Avatar
Just for my own education, what would cause the ignition to only act up after a while? Not tryin to put you on the spot-just tryin to soak some knowledge.
Old May 12, 2009 | 12:06 PM
Heat. Next to moisture, heat is the next worst enemy of the ignition system. It can cause problems that go away once components cool down.
Old May 12, 2009 | 02:30 PM
mech cb's Avatar
Ahhhh, so maybe that coolant/ oil he's smelling is it getting too hot which in turn is affecting the electrical. Got it. That makes sense. I figured maybe the oil was getting into the radiator and he was smelling that....
Old May 12, 2009 | 03:13 PM
The coolant/oil smell may just be a different issue all together.
95blazin
Jan 15, 2012 04:38 PM
K5BeAst87
Nov 5, 2010 11:51 AM
olenmarmcr
Dec 23, 2007 08:33 PM
prototype80
Engine & Internal
Dec 7, 2006 01:38 PM
codereddanger84
Nov 13, 2005 02:52 PM
