Blinker lens removel
Old Dec 17, 2009 | 08:25 AM
tony991's Avatar
tony991 is on a distinguished road
Default Blinker lens removel
How to you take out the blinker lenes on an 01' blazer?? I know clips hold them in but how to you get behind the lens to push in the clips??
Old Dec 17, 2009 | 09:38 AM
Sisk's Avatar
Well the actual lens itself comes out with the whole assembly. It's held in with clips as you mentioned. You need to remove the headlight first so you can see below at the clip holding in the turn signals.
There are 2 plastic tabs (see below) holding in the headlight assembly on the backside of the headlights. Just pull up on them and your headlight should come right out. Once you have the headlight out you should see the main tab holding in the turn signal. Squeeze that together and your turn signal should snap right out. Sorry, I only have pics of the top of the headlight assembly and not what it looks like with the headlight out.
blazintexas
May 1, 2012 06:01 AM
jsmith2260
Oct 7, 2010 08:07 PM
tony991
May 14, 2010 03:17 AM
kevin turner
Mar 3, 2010 08:01 AM
tony991
Aug 11, 2009 08:40 PM
