Blower motor how-to video
Old Jan 17, 2011 | 04:59 PM
blazinloud's Avatar
Default Blower motor how-to video
Well my blower motor quit today, searched here but couldnt find a diy, next stop was youtube and what do you know.
http://www.youtube.com/watch?v=Tj8hwQmR48E
took his advice, and smacked the plastic housing and it turned on! hopefully for a while
Old Jan 17, 2011 | 08:58 PM
Mark95603's Avatar
Mark95603 is on a distinguished road
I thought I was having problems with the blower motor since last winter. It would work intermittently, but usually wouldn't say on for more than a few minutes. I'll admit that I put off this problem way too long, but when you're unemployed things can get really tight.
After freezing my tail off for the last 2 winters, I talked to a guy I work with about a month ago and he told me that maybe the relays were bad or maybe a loose ground. I checked the wiring and the grounds and everything seemed to be tight, so then I went to pick n pull and found 3 of the relays, but they didn't help. Then about two weeks ago I went and started poking around engine compartment (after I seen this video) and kinda pushed and pulled on the two wires that go to the blower motor and one of them moved ever so slightly (1/32"). Started up the blazer and forced air finally came out of the vents. So far, so good. It's worked so far.
May not be the same problem you are having, but worth a shot.
Old Jan 18, 2011 | 10:04 AM
blazinloud's Avatar
i wish, mine has been making some weird sounds lately. sometimes it will only cut out half way and blow lightly on level 4. then if i crank to 1 then 4 again it will start up for a while, then slowly die again. sometimes cutting right out.
but in the video he says you dont have to replace the surrounding plastic and people say you might get fumes/smoke/exhaust entering. i wonder why gm didnt make a replacement part for that when they know you'll eventually be servicing it.
Old Feb 4, 2011 | 01:07 PM
chevytruckdood's Avatar
can we make this a sticky cause this awesome . i just ahd all my questions answered by watching this video....
maxvamp
Oct 31, 2020 08:19 AM
hanksta2
Jan 25, 2013 03:57 PM
SWATPARAMEDIC
Jan 1, 2010 03:12 PM
highlife756
Nov 16, 2009 03:57 PM
mike1of3
Oct 12, 2006 01:30 AM
