Blower questions
Old Oct 12, 2012 | 10:41 PM
pmezo's Avatar
pmezo is an unknown quantity at this point
Default Blower questions
So the air isn't blowing as hard as it should on my 1996 blazer. It blows on all the levels, but it's just not blowing hard out of the vents at all. I'm also hearing squealing from the blower from time to time. I'm guessing this has to be a bad blower, correct?
Looked over the DIY section and the install seems pretty easy. My question is about the part to buy. Looking on rockauto, they've got all different types of blowers for my years blazer... HVAC blower motor, without rear a/c, with a/c, etc.
So... which one should I get?
And does the resistor need to be replaced to? Everything seems to be in good electrical working order. I'm figuring it's just a bad motor and I'd throw a part at it. Am I going about this wrong since I've never had to do a blower before.
Old Oct 12, 2012 | 11:09 PM
Rottidog's Avatar
Not sure about the part for the blower or the resister.... personally I'd check vacuum lines. Spray brake cleaner over then as the engine idles & if the idle changes then change that vacuum line.
All of them, from the valve cover, the lines to & from the cab, to the vacuum canister, be it a bulb under the hood or the box in the DS fenderwell. To & from, check them all. The fenderwell is a pita to get, at but very important!
Old Oct 12, 2012 | 11:13 PM
richphotos's Avatar
If its not a vac line, just go through what you have, and what you dont have and that will tell you what blower to get, if you have rear AC, if you do not ect. rule them out.
Old Oct 12, 2012 | 11:19 PM
pmezo's Avatar
Are these the same vacuum lines the run the 4x4?
That's what I was thinking... just wanted to make sure. I'm not even sure if I have rear a/c since the a/c doesn't work. Pretty sure there's nothing back there though.
Any clue if the resistor needs to be changed too?
maxvamp
Oct 31, 2020 08:19 AM
SWATPARAMEDIC
Jan 1, 2010 03:12 PM
highlife756
Nov 16, 2009 03:57 PM
vankuen
Sep 22, 2007 05:26 PM
aspenpup
Jul 3, 2005 06:56 AM
