blown ingnition fuse
Old Jul 31, 2007 | 01:02 AM
davidh123's Avatar
davidh123 is an unknown quantity at this point
Default blown ingnition fuse
HiI was riding wiht my son inlaw today in his 2000 blazer 2wd.the engine mised onece and died. we were not able to get it to restart. The starter will not turn over and the guages and turn signal are dead. we found the ing fuse(40 amp) blown . we replaced it and it blew imediatly. So far have traced wiring to starter with no visible problme with the wiring. rmoved starter and was able to jump it with jumper cable . I am not sure where to begin in running down the problem. My son in law suspects the problem in in the ignition switch. If this is true does any one have asuggestion on the best way to test it. any help would be appreciated.
Old Jul 31, 2007 | 06:50 PM
davidh123's Avatar
Default RE: blown ignition fuse
Removed the starter. Then turned the witch to start fuse did not blow. This seems to indicate to me that the problem should be located in the starter circuit.
limited edition 1
Jan 27, 2023 11:07 AM
Denman3266
Jul 10, 2010 04:21 PM
92blazer92
Jan 22, 2010 06:38 PM
guillermoariast
Engine & Internal
Nov 11, 2008 11:34 AM
yzf125
Oct 6, 2005 03:31 AM
