Brake line question
Old Jun 15, 2019 | 07:50 PM
Mltoys's Avatar
Mltoys is on a distinguished road
Angry Brake line question
98 4 door, I blew out another brake line driver side front. . It looks like it comes from the rubber line then up.
does this go to master cylinder or a proportionary valve. Also is this easy to get to and do ?
itsprayed on my exhaust and steering column, smoked a bit.
thank you
Old Jun 16, 2019 | 06:32 AM
Mike.308's Avatar
thank you
Follow the trace and You'll find out. Be advised to keep up Your brake fluid tank full. The system is most likely gravity bleeding and if the air gets into Your ABS unit, You're in a big trouble. If You want to remake a new pipes, use copper-nickel material.
Old Jun 16, 2019 | 07:08 AM
Mltoys's Avatar
Thanks for the info.
Old Jun 17, 2019 | 08:10 PM
Mltoys's Avatar
I replaced the line, dont know if the thing ran dry requiring automated bleed which I have no idea what scan tool would do this.
Also my abs is non functioning, relay was removed because the first 5 or so stops would trigger the abs everytime it was started.
Old Jun 18, 2019 | 05:36 AM
Mike.308's Avatar
https://blazerforum.com/forum/2nd-ge...65/#post709471
Old Jun 18, 2019 | 07:58 PM
Mltoys's Avatar
Thank you
kevinph
18
Jul 15, 2018 10:56 PM
chevyblazer
Jun 20, 2014 12:32 PM
wisowebs
Dec 26, 2013 06:58 PM
Bobby_Lee
Apr 5, 2012 06:39 PM
Fusefinder
Jun 6, 2011 07:42 PM
