brake system troubleshooting!!
Recently I began to notice a sort of wobbly/heavy vibrating going on in my front braking system. Normally i would say that the rotors were going, but the symptoms aren't consistant. Sometimes I won't feel it for days, other times i feel it every time that i brake. Then intensity with which it occurs varies as well. Im thinking that it may be an axle problem, but really have no clue because i've never dealt with an axle prob before. Please help. I dont want to end up on the pavement!!
RE: brake system troubleshooting!!
I would check fluid level first, and then maybe when you are heating up the rotors, you are noticing the the wobble. might be a little warped!
thanks boss. I'll def check into that. The brake fluid level is fine, so maybe you're right on the warped rotors.
grdylan
06-05-2007 05:27 PM
z28chic
10-24-2006 04:37 PM
