A/C fan issues
Old Apr 14, 2020 | 07:11 PM
soflosayles's Avatar
soflosayles is on a distinguished road
Default A/C fan issues
So I’ve read the couple different posts about the subject but so far nothing has worked. I only have air blowing on speed 4 and it is only blowing through the defrost vents and head vents(regardless of which setting I choose). I’ve checked all the fuses and replaced them. I replaced the blower motor relay and resistor and yet still no luck. Anyone have any other suggestions?
Old Apr 15, 2020 | 01:18 AM
So you replaced the blower motor resistors? (below) Have you checked your under-hood vacuum lines? These supply vacuum to the actuators that direct to where the air flows in the HVAC system.
Old Apr 15, 2020 | 08:48 AM
Yes, I replaced the resistor and the relay that sits right above it. I’ve checked all the vacuum lines with soapy water and saw no leaks.
Old Apr 15, 2020 | 09:03 AM
I control unit itself was faulty at one time, odd temperatures and lack of certain fan speeds. Swapped it out with a used one from the ward and haven't had a problem since. That was 3 years ago. Might be something to look at, although it is rare that the control itself goes kaput
Old Apr 15, 2020 | 09:38 AM
That was going to be my next plan, I wanted a second opinion just to see if someone had any other ideas.
Mercury
May 18, 2019 12:47 PM
Jakin
Aug 28, 2017 05:45 PM
justblazin1
Feb 6, 2013 07:42 PM
speterson1011
Sep 26, 2010 08:01 PM
blazin_j
Oct 7, 2009 08:25 AM
