Catalytic Converter????
Old 10-11-2009, 11:31 AM
bigdaddykane93's Avatar
bigdaddykane93 is on a distinguished road
you guys are sounding like the material is as strong as steel, it's not, it's pretty fragile (that's why we can hear them rattle sometimes). like i said before, i did mine while it was still on my truck, just be sure to clear everything out before the exhaust gets put back together. i used a shop vac to vacuum out the last little bits.
i will try this and hopefully it breaks up. and any pieces that are still in there will come out on there own because i have no pipe, muffler, or tail pipe on my truck and has been like that for a while. so the pieces will just blow out as i drive around, lol...
Originally Posted by midnightbluS10
Go to your local parts store and look in the exhaust section. I lucked out and found a piece that was exactly the length I needed.
just curious, this test pipe piece at the parts store will not have a provision for the O2 sensor right? if not, then what should i do with my second O2 sensor? should i just tie it up as is and let it hang somewhere so it can read fresh air, lol? or do i unplug the sensor and hang up the wiring harness? just curious, what type of muffler do you have?
  #32
Old 10-13-2009, 09:08 AM
old skool luvr's Avatar
you can't just "deleate" the O2 sensor, it's gonna throw code, and affect your fuel mileage.
if your truck is already missing the exhaust (not really sure why..........) then just replace the cat. your truck is gonna sound like it's running open exhaust (with a punched cat), and be sure to get you pulled over orther wise.
  #33
Old 11-30-2011, 05:51 PM
BattleWagon's Avatar
BattleWagon is on a distinguished road
Can anyone direct me to a post describing how to remove the top bolt on the front of the cat? GRRR!
  #34
Old 12-01-2011, 07:26 AM
Cyberlight's Avatar
Cyberlight is on a distinguished road
What I did was snake my dremel up and over the cat from the back side to where my cutout wheel would allow me to cut the stud flush with the nut, then split both in two, to where I was left with a vertical cut that I could hit with a chisel to get the nut halves off. What a pain that job was.
88s10Blazer
09-21-2007 06:50 PM
dragon954
01-06-2007 07:33 PM
sgtbrum
12-18-2006 11:29 AM
88redk5
Headers, Intake, & Exhaust
10-26-2006 06:24 AM
Mbastet99
08-25-2006 09:34 PM
Quick Reply: Catalytic Converter????
