Computer Swap
Old May 8, 2010 | 01:45 PM
LowLife's Avatar
LowLife is on a distinguished road
Question Computer Swap
I want to send my pcm for my 98 gmc jimmy 4dr 4x4 out for a tune, I still have my pcm left over from my 97 bravada, I want to use the 97's until mine comes back. Visually they are the same Computer, Except in between the top 2 plugs there is a small round hole on my 98's pcm that was not used, But on the 97's there is a open spot to plug in a connector. Can i still use this temporarily, Or will this place my truck into some type of security lock out. Sometimes it does hurt to try .
Old May 8, 2010 | 02:36 PM
NVANZEE's Avatar
Check if the numbers on them are the same. Otherwise try plugging it in. You might find some of the connectors wont fit. I would think it would be fine as long as both had the same options.
Old May 8, 2010 | 03:38 PM
LowLife's Avatar
Well i know the 4 main plugs i have plug in no problem, But i did that with the battery + off. I did not wanna try to start the truck, And cause some kind of miscommunication do to the little plug i dont have on my harness. I was thinking the extra plug was for the Awd, But im not sure. By the way how are those Km2's treating you?
abig84
Jan 5, 2012 08:23 PM
Security
May 25, 2007 04:26 AM
Walleye
May 5, 2006 10:15 AM
chevyheavy
May 1, 2006 07:31 PM
KA3AX
Apr 21, 2006 05:20 PM
