coolant leak, what should I do?
Old Sep 4, 2012 | 07:00 PM
kmartin's Avatar
kmartin is an unknown quantity at this point
Default I hear water swishing around going around turns
I hear water swishing around to the front of my vehicle when I go around turns. Do you think this is related to a leaking radiator? I tried look under the vehicle for a clogged drain and couldn't find one. If its not radiator, where could I find trapped water?
Old Sep 4, 2012 | 08:16 PM
Rottidog's Avatar
If the rad is leaking you're probably dragging air into the system.
Does the swishing sound happen when you're driving or just sitting still while the engine is running & you turn the wheel?
Old Sep 4, 2012 | 09:20 PM
Melrock83's Avatar
Melrock83 is on a distinguished road
Im on my 3rd radiator in a yr...dont no if ur blazer and my 95 have the same style but if its plastic on each end then they dont call em throw away radiators for nothing...I flushed and replaced all but the heater core and water pump in the cooling system to find out it was my radiator. Then 4 mths later THAT brand new radiator blew out the side. The first two didnt leak til pressurized so test before u invest!!
Old Sep 5, 2012 | 05:34 AM
kmartin's Avatar
The leak is on the plastic part of the radiator. The swishing or water moving sounds when i am going around turns. It sounds like there is water trapped somewhere. The sound sounds like it coming someone where from the front of the vehicle. Try to shine a light in the cowl area but didn't see any water. Could there be water trapped in the fire wall?
Old Sep 5, 2012 | 03:29 PM
Melrock83's Avatar
The sound u hear is coming from ur heater core...as long as u hear it and u dont have a wet pass floor board and u still have heat then dont worry bout the sloshing/swishing water sound. The radiator crack has just allowed air to get in the system, so that will b takin care of when the radiator is replaced.
Old Sep 12, 2012 | 06:57 PM
kmartin's Avatar
Well, I got the radiator replaced by a garage today. Added more coolant. However, my water sooshing is still there yet. Sounds like it is coming from the passenger side of the vehicle in around the dash area. This water got to go. I suppose there is a drain that got clogged and anyone with any insites would be helpful.
Old Sep 13, 2012 | 09:14 AM
chcknugget's Avatar
chcknugget is on a distinguished road
As others have said you have air in your heater core. You need to purge the air from heater core- first elevate the front two tires on ramps. With the engine cold remove the radiator cap and start the motor. When you first start the motor the water should be at the rim of the radiator cap. If it's not add coolant. You'll have to wait about 5 minutes for the thermostat to open, and then you'll see the water level drop and you'll have to add more coollant to compensate for the air being flushed from the heatercore.
lionpaw2012
Jun 8, 2015 01:07 PM
trobbins
Jan 9, 2013 10:17 AM
AcerDeucerQ
Dec 3, 2012 06:29 AM
Skeeter Cruz
Mar 4, 2010 07:07 PM
TAZ454
Jan 28, 2008 10:11 AM
