Driving and random grinding noise happened
Old 12-31-2015 | 07:53 PM
Red Sled's Avatar
Red Sled is on a distinguished road
Yep. Does the Sound like its coming from the front passenger hub??? Time to change your transfer case switch. Dorman part# 600-500. Also check the accuator thats under your battery. There are a few great U tube video on Blazer 4x4 accuators.
Old 01-01-2016 | 04:39 PM
I agree, transfer case vacuum switch leaking internally, which partially applies the clutch shaft in the RF axle. Under $20 and 15 minutes to replace it. Only the 3 button transfer cases have the vacuum switch. 4 button is done with an electro-vacuum switch on the firewall.
Old 01-31-2016 | 03:30 PM
Fatguy9's Avatar
Fatguy9 is on a distinguished road
I tried to change the transfer case switch yesterday and I couldnt find it at all, Is there any other kind than the 3 hoses?
Old 01-31-2016 | 04:32 PM
The vacuum switch is ~ 2.5" long, and looks like this:
The vacuum switch is above, and slightly inboard, of the encoder motor, on the driver side. The image below is an NV233 transfer case, (just like yours). The vacuum switch is visible in the image.
Attached Thumbnails Driving and random grinding noise happened-49315or600-500transfercaseswitch.jpg   Driving and random grinding noise happened-nv233selectable.jpg
Old 02-12-2016 | 08:37 AM
Fatguy9's Avatar
So i looked again today and it was right infront of my face the whole time, I feel a bit blind but i went to change it out and it was such a pain because it was so tight and not enough room to work with but i finaly got it and the old one was so done, anyways so far so good thank for all the help Driving and random grinding noise happened-img_5636.jpg
Old 02-12-2016 | 11:16 AM
Glad you got her fixed. Thanks for posting back!
Bigredk5
11-21-2015 09:42 AM
Bolbol
02-02-2015 02:55 PM
gjeffries1987
12-17-2014 08:23 AM
lannon_j
10-27-2014 05:36 PM
garynye30
10-15-2010 06:34 AM
Quick Reply: Driving and random grinding noise happened
