Engine Swap
Old Feb 27, 2008 | 02:06 PM
SCOTTY's Avatar
SCOTTY is an unknown quantity at this point
Default Engine Swap
Hi All:
Does anyone know if a 2001 4.3 Vortec out of an S-10 pickup will go into a 96 S-10 4.3 vortec Blazer with minimal problems? any help is greatly appreciated.
Scott
Old Feb 27, 2008 | 02:25 PM
Default RE: Engine Swap
Should be no sweat. They are basically the same motor. It wasn't until mid-02 that things started to change minutely with some of the sensors, etc. Your y-pipe and wiring harness will have to be used as your truck will have 4 O2 sensors and the associated wiring for it, but everything else should be the same.
Old Feb 27, 2008 | 05:30 PM
SCOTTY's Avatar
How about the computer end of it? Also someone mentioned the injectors are probably different?? I don't want to buy it if it won't work
Old Feb 27, 2008 | 06:12 PM
The injectors are backwards compatible, but as I said, that didn't change until mid-'02. Everything on the '01 motor will be the same as what is on your motor. Wiring removed and sitting on engine stands, you shouldn't be able to tell any difference between the two.
Old Feb 28, 2008 | 11:07 AM
SCOTTY's Avatar
ok, thanks alot, i am going to go for it then
scott
Old Feb 28, 2008 | 11:17 AM
No problem! Sounds good!!
Be sure to let us know how things go when its all said and done. And if you have any questions along the way, just let us know and we'll do our best to get them answered!
Old Mar 18, 2008 | 06:45 PM
SCOTTY's Avatar
Anybody know how many bolts are in the bell housing/block? I took out 7 but can't seem to break it apart....1996 S-10 blazer 4.3 Vortek
gmoney30
Jul 5, 2010 08:51 PM
SureShooter29
Mar 18, 2010 03:02 PM
gmoney30
Jan 22, 2010 07:07 PM
ronnyrum1
Engine & Internal
Dec 11, 2005 11:34 AM
billybird
Jul 20, 2005 11:17 AM
